breather question
Neelsonwheels
Anyone know what issues a sticky PCV valve could cause.
I have looked into my PCV system and found the valve that goes to the throttle body seems to open with very little vacuum but the valve that comes from the intake after the air filter open but requires what I think is alot of suction(vacuum).
I removed the hose and sucked on the tubing(air cleaner end) and it did open but it was not easy.Shouldn't this valve open with little vacuum?Also it doesn't look like the valves in the manual.It is a straight valve not a 90 like the other one.Any help would be great.
Neels
