Re: Boost holds back after 8psi,,,need help
i'm not sure if this is your problem, but yes a plugged exhaust will cause a severe drop in boost. Just had a customer bring in a ty complaining it wasnt making boost. Seemed to drive fine, but under a load it would bog down and not build any boost. You could hear a whistling noise (very high pitch like a bad wheel bearing or something coming from under the truck) At first it sounded like it was coming from the flexplate area, but once i got it on the lift i could see a large exhaust leak on the inlet side of the cat.. Basically it had clogged up so bad it was coming out through a slip joint in the exhaust.. Cut cat off and sure enough it was all broken up.. DIdnt help either the guy had a 2.5" exhaust installed on his ty with a flowmaster muffler (so we changed all that as well)
Granted there is not a substantial amount of detonation present, I'd check your compressor blades on the turbo, then pull the wg line and watch for an overboost. If it still wont make boost, then i think your exhaust is plugged.
