Body Bump Stops
Trizney
I tried searching, and could only find info on the front ones.
How many bump stops are there total on a Typhoon?
Where are they located?
What are the part numbers?
How many bump stops are there total on a Syclone?
Thanks in advance.
Trey
Trizney
Crazy J said:
do you mean body mounts?
if so then there's 10 on a ty and 6 on a sy.
I guess I meant body mounts. Are body mounts sometimes referred to as a bump stop? If not, what are the differences?
Trey
Crazy J
bump stops are what the upper control arms and rear axle hit when the suspension is compressed.
body mounts seperate the body from the frame, so there is no metal to metal contact. stock is rubber but Energy Suspension makes urethane ones that will aid to stiff the chassis a little bit (less flex).
