blowoff valve
atkonkler
Is this your bush?
I'm curios to know what blow off valves people use and where they bought them. Just taking a survey too see any info would help and if anyone has a good ones for sale here and no Chinese crap either.
Darin
Re: blowoff valve
I'm going to use a stock Talon/Eclipse (90-94) on my Typhoon. No ricey noises, just a large whoosh. It'll hold 25psi if you crush it slighly.
Other option is Tial. Again, no ricey noises, just a whoosh. I had one on my last Talon. Worked very well.
atkonkler
Is this your bush?
Re: blowoff valve
Which tial? Do you use? Where is the best place to buy it? Does anyone have a picture of where the best place is to mount it on the turbo to intercooler pipe? Is that all it is is just mounted there ? No vacuum lines or electrical plugs to go anywhere
mattw
Re: blowoff valve
Thats what I'm running.. I ran it on my Typhoon and I have it on my clone now..
Its not the prettiest thing so I hid it on the bottom of the intake plumbing..
93Ty#0818
Re: blowoff valve
Stupid question but, where's the factory BOV located? Also, is it a bov from the factory or does it recirc into the intake?
Darin
Re: blowoff valve
www.forcedperformance.com for the Tial BOV.
There is a vaccuum line that comes off your brake booster line that would be required. Actually, anywhere off the intake plenum, but the brake booster is a great source.
atkonkler
Is this your bush?
Re: blowoff valve
Is the tial q ok for a stock set up with the 11psi spring that comes with it? And does anyone have pics of it hooked up? I will be tuning in winter and spring. Any tips are helpful with choice of bov.
DanenGraham
Big in the rear
Re: blowoff valve
Factory BOV is on the backside/bottom of the intercooler, right by the coolant lines. Keep looking you should be able to find it....
EDIT: j/k
alwayscode390
pppssssshhhhhtttttttttttt
Re: blowoff valve
Some people argue that a BOV isn't necessary on an automatic transmission vehicle since the throttle body is always open during shifts. It would release after a heavy throttle to no throttle though... I would think, right? ---
Icarus-54
Donating Old Member
Re: blowoff valve
It doesnt matter what trans you have, a bov vents the pressure between the throttle body and compressor.When you let off the gas a cetain amount of pressure is trapped and can only be released by stoping the compressor wheel and cause it to spin backward.That is not good for the turbo bearings.I run Tials on all my truucks,even the stock ty.Turbos cost too much.
atkonkler
Is this your bush?
Re: blowoff valve
By intercooler you mean the intercooler connected to the throttle body correct? I didn't even know that typhoons came with BOVs on them stock cause I've never seen then when I've taken the upper part off to replace cooler lines with rubber lines.
atkonkler
Is this your bush?
Re: blowoff valve
I didn't think there was a bov at all on these trucks so I take peoples word for it sometimes ill give them the benefit of the doubt but now I'm questioning that sometimes. I just like to ask questions if I dont know the answer I'm gonna ask someone who maybe does. Just trying to avoid mistakes and find out what works best.
aasltmike
Re: blowoff valve
I got an HKS SSQV on mine...screeches loud as hell. I got it for free from a former co-worker of mine. Free works for me...LOL
asmo
Sy #2918
Re: blowoff valve
I had a bov flange welded to a aluminum 90* intercooler pipe
I think its 2 1/4" the I ran a tee on the vacuum line by the throttle body
here's a pic, its a hks knockoff works good.
Re: blowoff valve
JGS
100% American made, very reasonably priced, sound awesome and are proven (very popular with the LSx guys.)
