turbojimmy
Hi all,
Ever since I've gotten my truck, it's run pretty rough. I've narrowed it down to the #1 cylinder fouling the plug with oil. Not a lot of oil, but it doesn't take much to foul the plug and lean out the mixture enough that it pings. I'm also missing oil - a quart or so every 5-600 miles. It's not dripping enough to be losing that much, and it doesn't smoke. I noticed yesterday, though, that the antifreeze is thick and oily. There's no antifreeze in the oil, though. The other weird thing is that I can't keep antifreeze in the CAC. I don't know where it goes, but I noticed that there's antifreeze all over the CAC (coming out the cap) AND the heater motor - it's blowing out the recovery tank. It only started doing that when I hooked the overflow tube on the CAC to the overflow tank (like it's supposed to be - it wasn't like that when I got it).
I know the recovery tank shouldn't be pressurized, but I don't know how that's happening. I've had two different CACs on it (thought maybe one was leaking boost into the water) on it. The radiator has the right amount of antifreeze in it, and it seems to be drawing it in as it needs it. I had a T-Bird with similar symptoms that had a blown head gasket, but the radiator would always be bone dry because the head gasket leak was pressurizing the system and blowing all the antifreeze out. I don't see that happening with the Ty, but something funky is going on. When I get on it, I can smell antifreeze - blowing out the CAC and the recovery tank.
Any ideas?
Jim
Any ideas?
Jim
