ball joint eater
kmack
Bought my truck with 17" x 9.5 rims and 275x 50 tires.
Within 3 months I had to replace all 4 balljoints with excessive wear.
Don't think these front suspensions are engineered to support that much tire and that much offset:tdown:.
Running stock rims with 245/50's
ty166
Re: ball joint eater
typical... even non syty s-10 / 15's eat ball joints....... and idler arms....... and pitman arms....... if you don't like doing ball joint you bought the WRONG vehicle.....
Is your truck lowered? They lower it is in the front with the factory suspension, the quicker it will wear out the ball joints.
The ball joint /tire size is not the issue. What ride height do you have, what brand of ball joints are you buying and using.
Chevymec
What brand are you using? I had a Dodge truck that the customer wanted me to install some drive works ball joints. No problem until both snapped off about the joint about a month apart from each other. Another truck, 4x4 chevy used the same brand. Those lasted about 2 years. I only use Moog now because of that.
