Autometer FP gauge wiring diagram... - pls help
Falco
Howdy,
I've accidentally pulled out the terminals from my Autometer full sweep electric fuel pressure gauge's connector. The connector looks like this:
I'd like to know which wires goes into which terminal. There are five wires, three from the sender (red, black, purple), ignition and ground. If you have such a gauge, pls check the connector and tell me which wire goes where. Let's say the terminal number's look like this:
1 2 3 4 5
6 7 8 9 10
BTW, the whole thing happened because I've relocated my gauges like this:
Thanks in advance,
mattw
I've got that guage.. Been so long since I installed it that I don't remember where that connector is... Back of guage or on the little controller box? Let me know and I may be able to snap you a pic...
-Matt
falco, i have one in the garge or at the shop - i will look a bit l8r tonite - worst case, i can find out for you tomorrow - i will be home by 6 eastern usa time.
if u dont hear from me by tomorrow nite, pls email me (regular email, not board email) and remind me!
but, either way - i can help ya out
mike
Loeryder
Click for the larger version.
Here are the instructions from mine, although the plug you show looks to be diff.
Mine is a flat terminal strip.
If your plug is numbered you may be able to piece it together.
that's a totally different setup - older style, no relevance to the new kind.
new type has no interface box - 1 connector from gauge to sender.
i dont have 1 here - will get it tomorrow for you
Falco
Thanks Mike, I appreciate it.
Jason, as Mike said, I'm using the newer style with no controller/memory box at all. Thanks anyway...
Matt. If it's the newer style and you have no controller box, then I'd be interested in picture of the back of the gauge with the connector connected.
Thanks guys,
1=red
2=black to sender connector
3=black to chassis ground (shorter wire does not go to connector at sender)
4=empty
5=empty
6=purple
7=gray
rest are empty
