And so it begins (smack talk)
storm
well my friends know I just bought a sy(its not even here yet ) and i'm already getting the why did you buy that slow sob...... AHHHH . well its bones stock o I know I need to cover the basic tune stuff / fluid changes and all.
My one freind is running a 06 gto 6-speed intake,drag radials,exhaust
other buddie is running a 02 vette 6-speed,intake, longtubes, full exhaust, clutch upgrade, tires,longer rockers and a good tune.
Lets use this old truck and make a bunch of b****es out of them. :tup: tell me what you would do. I got about $1,000 to use
I am a 1/4 mile guy only, I know i will not be able to make any highway runs against a worked vette.
gjp
another post whore
Re: And so it begins (smack talk)
I ate up a 06 gto last weekend. See my mods in my sig. I had him up till we let off(90mph) We looked at each other from a light and both jumped on it hard. The guy had at least an exhaust setup because you can hear it. check this out: http://www.sportmachines.com/maintenance/recipe1.php its a good start.
The biggest thing is make sure your truck run fine with no knock retard. With a proper boost launch you should beat all of them off the line, it just a matter when do they pass you. If you get them off thier drag radial crutches, it will take them almost a full quarter mile if they do pass you.
The combination below with a good running truck should do a 12.5 in a Sy.
Some of the parts are dated (IC Pump Switch not needed), ATR exhuast discontiued, there are other 3 bar recipes. After this you will eventually need to address the front propshaft & motor mounts. You also will want to address the transmission cooling (Cooler & Deep Pan) because that will also eventually go as well.
It's just a six
Super Member
GTO's have a really hard time to launch hard, so you should eat those up easy on the start.
At a 2700FT track they run 13's all stock @ about 98-100mph.
My friends 04 ran 13.01 best but he spins alot w/stock tires.
He put a SLP full headers, exhaust "loud mouth" mass 80 mm air flow sensor,K&N & Grannatelli tuner programmer & it's slower than when it was stock.
Corvettes are better for launching, lighter car they seem to run 13's @ 2700 ft track being stock.
GTO's will beat you top end (Highway speeds) also, they are not too slow a car from 100 & up.
But I spank his 04 GTO anywhere below 100 & my friends 2001-2002? BMW M5 below 100
storm
I will run with the recipe if I can find the ultachip and some 50's cheep.
We went to the track this week and the gto put down 12.8(06)
the vette went 12.6 both guys are good drivers we have all had fast cars for 12-years or so
gjp
another post whore
Those are some fast times. You will need a good tune and those mods just to keep up with that.
Those are some good times, so you have your work cut out for you. Don't dispare a good running Syclone will have your friend clammoring for more mods..
storm
thanks !! I got a real good deal. Thanks for your help. i went with a little more miles (80K) so its still strong but I'm not affraid or f-ing up a mint low mile truck. (also gives me some extra for mods :)
