EcSy#2671 said:anyone know of a way to get 12 volt power and Ignsion source without cutting it to i the trucks wiring
I just installed my AEM wideband today took my about an hour.The hardest part was fishing thoes big wires up the pilar.On the harness with the four wires(red-black-white-blue) I only used two the red and black.In the fuse box there is an ignition that is not used i put the red wire there and ground black.I'll post up some pic tomorrow if you need to see what i did.Works fine when i fired it up.EcSy#2671 said:it is easy wiring RED BLACK and WHITE, and blue is for a stand alone. I was wondering if anyone know of a way to get 12 volt power and Ignsion source without cutting it to i the trucks wiring
