A/A IC Links.
wantingasy
Re: A/A IC Links.
HotRodV6 said:
Well i recently bought a FMIC designed for a Buick GN and it seems to fit pretty good, and i think it will still leave room for the a/c condensor once its all in and mounted. The core suuport will need to be trimmed and cut out for cleanence, but basically im going to have the in and out on the bottom with the FMIC recessed into the factory rad cutout in the core support. Im thinking it wil be a nice and clean install once its all said and done.
http://cgi1.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItemWithCategory&item=8042152498
How are you going to route the piping with the inlet/outlet facing outward like that?
Re: A/A IC Links.
The pipes will face the engine and exit under the core support. and im going to try and keep all the pipes between the frame rails, so that whe it comes time to reinstall my inner fenders there will be no interference problems. I will also be ditching the stock fan setup for either a volve fan or a dual LS1 fan. I like the volve fan better as it takes up less room. Im also going to be using 2.5" IC pipes.
