9/11 converter & MSD stuff
Aeroking
e.i.
FREE SHIPPING IF YOU ARE GOING TO HOMECOMING 2012 !!!
TV cable, universal style, 36" fits syty, requires a trans pressure gauge to set.
$40 + shipping
4" brake cooling duct 4ft long, black, reinforced, good for a DIY cold air intake, good to 300deg
$30 +shipping
7749 ECM aftermarket, used, works fine. NO memcal.
$50 +shipping
F.A.S.T. V8 (L98) injector harness. Brand new.
$80 +shipping
Stock SyTy injector harness, used, works
$30 +shipping
Ostrich 2.0 emulator & ribbon cable & USB cable, used, works
$100 +shipping
GMC grille, Chinese knockoff from LMC truck, spray painted black, with gray grille & headlight buckets. Includes stock GMC letters, and stock marker lenses.
$75 +shipping
17" wheels. 1989 corvette 17"x9.5" wheels. Syty centercaps. Powdercoated light gray. 2 are in perfect condition, the other 2 have scrapes on the inside lip, where it hit the control arms. About 600 miles on them.
$300 +shipping
TCS Torque Converter billet 9/11 3600stall, for a 700R4, full lockup, dual antiballoning plates, freshly rebuilt, 0 miles
SOLD
MSD 2step launch module 8739, for plug-n-play use with msd cd ignition boxes. i'll through in a set of 3000-3800 (odd) pills.
SOLD
MSD adjustable RPM pill module. MSD-8677 between 1000-3000rpms. (for a MSD box or 2step)
SOLD
Posi-lok #500 actuator cable kit. New in box, never opened. If you want to make your truck switch from RWD to AWD.
SOLD
QTP single electric cutout, 3", switch and harness, i'll throw in a polished 3" Y pipe with the flange on it.
SOLD
Tialsport external wastegate, F38 (38mm), "ok" condition, works great, scratches on polished housing, comes with a 10psi spring (good for 10~20psi with a boost controller), comes with tin gaskets, and hardware, also has a new mild-steel flange for the exhaust side, sorry no flange for the intake side. This is an early F38, so the valve is rated for unleaded gas, not leaded.
SOLD
Phil-n-Tex bolt-on front driveshaft loop.
SOLD
For pics of anything, PM me.
sycho
Re: 9/11 converter & MSD stuff
has anyone ever used the posi lock with the cable to switch from awd to 2wd?
Aeroking
e.i.
i had planned on running DRs and would have needed to warm them up, but i havent gotten that far yet.
As far as installation, from what i've read, you need a front axle housing (just the tube side) from a 4WD s-series. It has an actuator to disconnect the axles. So other than this cable, you need the 4WD axle tube, and its 7 bolts and its in.
Waller did a write up on it a few years back.
http://www.sportmachines.com/gallery3/index.php/Vendors/JWaller-and-his-creations/jwaller_ty/jwaller-album23
sycho
cool, thanks for the info! ill have to think about that later, need to get finished the build first.
Aeroking
e.i.
bump for the converter. PM me offers or trades. Headers would be a good trade.
DanenGraham
Big in the rear
Sorry, i really dont want one with the solid emblem.
But thanks for getting back to me!
T-Bone
$300 +shipping
Dibs on these for now. Need exact size of tires and verification that they are a matching set. Also, would like a quality pic of the SyTy centercaps all together. Pretty sure I will be taking these off your hands :tup:
