Forgive me, but I have to do this.
Lets look at what is most restrictive. The stock throttle body plates are 48mm in diameter each. Conversion from mm to inches: 25.4mm = 1 inch.
48/25.4 = 1.89in
Area = pie x (d/2)^2
= 2.805 square inches per plate
x 2 plates = 5.61 square inches total
Inlet to IC is aproximately 2in diameter.
Area = pie x (2/2)^2
= 3.14 square inches
So the cross setional area that air flows through the stock throttle body (neglecting the thickness of the plate and shaft) is 5.61in^2.
Whereas the cross sectional area for the inlet of the IC is only 3.14in^2
Consider that along with the fact that the throttlebody is a lot smoother passage than the rough and abrupt IC inlet and it kinda puts things into perspective. If you want to get more airflow, look at the IC inlet first.
_________________
Joe Lutz
Steel lernin hoaw to speal
communities.msn.com/joeelutz
<font size=-1>[ This Message was edited by: joemama on 2002-01-11 00:18 ]</font>
