Turbotrux
Hey everyone.....I have been thrown in the middle of someone elses mess - that someone else isn't a Ty owner, but my current employer who owns a shop and screwed this poor guy's ride up.
Here's problem no. 1: The Ultimate Chip (guage style) 9 times out of 10 resets it self to T2 F2 when the ignition is cycled. Has anyone had this happen? Any thoughts?
Problem no. 2: When the owner wished to have mods done, no base-lining to the vehicle was performed - I know it was towed in.....that's all.....after that, parts were thrown at it and here's what is currently on it:
1: 50# Ultimate chip
2: PTE51 Turbo/downpipe/cat kit (that's what is on the paperwork, but the receipt from RPM says PT44...so I don't know what turbo is in it!?!?!
3: APFR
4: New ECM (dealer)
5: New Prom (dealer)
6: New o2 sensor (dealer)
7: 170 deg t-stat
8: New plugs & wires
9: 3 bar map sensor
10: Walbro 255 fuel pump
11: ATR Water/Air IC
And last, but not least.....there were 50# injectors ordered...installed...then removed because "it ran like shit", so the OEM injectors were put back in.
Now.....in my mind....if the chip is designed for 50#'ers and you've got stock'ers (28#ish??)....it will be LEAN - right?? That's why the little red knock light blinks so friggen fast it looks solid and ALSO when you're in upper boost (12+) the truck shakes like a missfire.
This work was performed starting October of '03 - evil boss man gave his BS stories for about a year (hmmmm just enough time for warranty to expire), then sold him ECM,Prom, O2 sensor, plugs, wires, super cold t-stat at end of '04....
Let me stop here.....And moderators let me know if this post is in the right area.
Thanks and I eagerly await your replys.
-Rob
3: APFR
4: New ECM (dealer)
7: 170 deg t-stat
9: 3 bar map sensor
-Rob
