sytyfreak said:
Thanx for the info guys
But, heres my problem:
I want to run a 3 inch DP on anyway I choose to go. If I do the 20G upgrade I want to run a 3 DP, but I haven't found another DP other than the ATR (which I'm trying to avoid because of some negative comments I've heard) that would fit with the stock headers and will fit stock turbo/20G. I don't want to go PTE since I already have a TIAL wastegate. And my other option the RPM DP(for Ext. wastegate) is designed towards a Garret style turbo and Innovative gate(correct me on the innovative comment, if wrong).
I've been thinking going PTE(TE-44) but I would like to keep the TIAL and I don't want to disable the PTE's internal. On the other hand I like the 20G because it's a direct bolt on, but I would like to run a 3 inch downpipe too and I can't find one other than the one Morgan was offering but it hasn't been finished. I've also have considered going with an RPM kit(since I like externals) but that would also mean I have to get ridd of the TIAL :x
What would you guys do if you were in my shoes??? Also if there's any other option that I haven't noticed or didn't mention please feel free to comment.
Thanx!
I've been holding off changing my turbo setup for a long time, basically because once the new motor is built, I'm going to go larger than the .63 a/r housing that I have now.
I will be putting the Tial 40 on the crossover, and thats what I plan to use on anything in the future as well.
I know of one person that bought the PTE kit, and has since went back to an external WG on the crossover, and wired the integral shut. I'm not saying that PTE setup isn't great, its just I've seen that most who have used an external WG, usually can't be happy with an integral.
If I use this TE44, I'll change the housing to possibly a .82 a/r that doesn't use an integral. I'm not exactly sure which housing I will use, but it will be a 4 bolt, and if needed I might have to use something like this...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2409229047
if the housing was initially made for an integral setup. I'm not sure I've seen all the options for garrett 4 bolt exhaust housings, running external WG's on the crossover, so correct me if there is a better solution, or an easier one.
I will most likely stay with the garrett turbo, and if needed, buy some 3" mandrel 180's and do something on my own. The important thing with garrett turbos is to stay away from the 3-4bolt adapter off the manifold, you don't want that....they leak.
If Jeff can make a 3" downpipe for a 20g , allowing you to retain your Tial on the crossover, I'd say go for it. Even if you decided later on, to upgrade turbos....I'm sure you'd have no problem whatsoever selling that downpipe on here.
Nolan: Is Tony using the integral wastegate? I'm not 100% sure my problem is fixable, even if I pulled it off and repaired whatever it is causing the puck to hang up. It was basically a new turbo when I got it, and the arm that controls the puck seems kinda junky.
