20G difference
tylex
Hi guys!
Have a Mitsu turbo laying around and wondering if its a 20G because the inlet looks a bit bigger than the stock one.
How can i see from outside what kind of mitsu it is?
Thanks a lot!
greets,
Alex
James Thomas
"NO CLASS"
Re: 20G difference
Should be cast / stamped on the compressor cover. Post a pic and or measure the inlet / outlet. The ex. housing should be marked 14 cm (if all original). I'm sure several of the "20G" guru's will chime in also.
__________
James
It's just a six
Super Member
Re: 20G difference
20G does have a bigger inlet ID.
The compressor housing also has a large machined flat surface on the inlet side.
Bolt pattern for the wastegate actuator is different.
What P.N is stamped on the compressor housing?
Also what size is the turbine wheel hole,where the downpipe attaches? ;)
Re: 20G difference
Think this is a 20G
HTH.
Re: 20G difference
The compressor housing also has a larger machined flat surface on the inlet side.
Inlet ID I will agree with, OD and the tube used (which is what most people measure) is the same.
jwaller
Evil Genius/SyTy Guru
Re: 20G difference
Quickstop [UK] said:
Think this is a 20G
HTH.
this is def a 20g. the 20 g will have a straight rod for the WG actuator. the stock one has a bend in it.
the stock turbo has a 8 cast into the inlet of the turbine housing.
20g has a 14 cast inot the inlet of the turbine housing.
stock compressor wheel has single blades.
20g has a double row of blades.
Re: 20G difference
Hmmm....I asked about that ages ago :squint:
At least now I know for sure. Still don't know if it is busted - oh well - new GT35R here I come!! :D
It's just a six
Super Member
Re: 20G difference
If you are going/trying to decide if you have a 20G or stock turbo,most people do not measure the OD of the inlet,you need to measure the ID to see if you have a 20G compressor wheel or larger.
(so, most people would not measure the OD,,,you need to measure the ID,,, correct?
tylex
Re: 20G difference
Okay,now i know that its a 20G!!Thank you all for the quick answers. :tup:
Last question:How much gain would i have with this turbo?(maximum hp)
regards
jwaller
Re: 20G difference
over stock you might gain 20hp. but to get it you need a 2800 or better stall converter with a stock truck.
It's just a six
Super Member
Re: 20G difference
regards
My Sy made 386 HP @ the rear wheels (21 PSI) with a 20G turbo,but it has a 12CM turbine housing.
Tested on a Dyno pack dyno.
Stock 2100 RPM stall converter.
tylex
Re: 20G difference
386hp on the wheels!Thats nearly 450 on the engine right?That would be enough for the beginning. :lol:
Thanx for the help guys! :tup:
greets alex
