IA 1996 s-10 Pro street sell/Trade
elec87
I'm Looking to Sell or possibly trade my 1996 s-10
http://s104.photobucket.com/user/Hugger2/slideshow/
More pictures here:
http://s104.photobucket.com/user/Hu...&page=1&_suid=1380473624852017659821896429556
355
Edelbrock Performer rpm heads 64cc
Harland sharp 1.6 Roller rockers
Competiton camsMagnum 280h Cam kit 280/280 @50 230/230 ll0 lsa
Performer rpm Air gap Intake 350-7501
Holley street Avenger Carburetor 80770
Pete jackson Gear drive
Msd Probillet Distributor 8551
Msd 6al Ignition box
msd 31233 8.5 Plug wires
Msd 8207 Blaster coil
Msd 2 step
Milodon Pan
Milodon 18313 HV pickup
Melling 10555 Oilpump
Felpro 375-1880 One piece Pan Gasket
Arp Stainless Fastner kit
Arp 134-3601 Head bolts
Arp 230-7003 Oil pump stud
Arp 200-2902 Flexplate bolts
Sanderson 1 3/4 Conversion Headers Coated
March Performance Serpentine Kit 655-22031-09
March Alternator Fan 221-09
March Alternator and waterpump cap Kit
Summit High flow Fuel pump kit G3136
Summit polished Fuel Regulator 63131
Jegs High Flow water pump 555-51033
Jegs 45* Swivel Aluminum Thermostat Housing 5111
Summit balancer 161358
Summit adjustable timing pointer 163800
Milodon Stainless steel dipstick 22000
Jegs Prostarter 555-10001
Jegs throttle spring Bracket with return springs 555-15230
Remanufactured Dorman ps pump
Mounted with carshop Engine Mounts
Moroso Valve covers 68415
Summit Radiator 380473
Electric fan kit
Dorman Reman alternator
Exhaust
Flowmaster Mufflers with a full exhaust that runs from front to rear
Electric cutouts mounted Under the cab that can be actuated via a console mounted switch
Transmission:
Built by a local shop with less than 500 miles Performance clutches
Tci 399273 Sfi approved Flexplate
Reverse Valve body Tci 221500
Trans Brake
Tci 241002 Super street fighter Converter 3500-4000 stall
Jegs 555-82510 Engine to block Bolt kit
Lokar billet dipstick
Wiring:
Painless Harness 12 circuit 8 switch Panel 764-50003 (controls whole truck)
Panless Fan Thom Electric Fan relay kit 30103
Painless 50102 Fuel pump Relay kit
Chassis:
Beltech 2100 Drop spindles
Beltech 4220 2" drop springs
Beltech 1 1/4 swaybar 5420
Prothane bushing kit: This covers Body, control arm and springs bushings 7-2020
Dorman remanufatured Gear box
New idler,centerlink,tierods,pitman and idler arm (under 3k on these parts)
Spohn Tubular upper control arms
Kyb shocks
Competition Engineering Real coil over kit cee-2051
Competition Engineering Diagonal Lik c2052
Competition Engineering Coil Spring c2560
Competition Engineering Ladder bars
Energy suspension 9-6102r Coil isolators
Energy suspension 9-9150r Bump stop Kit
Ford Nine inch 4.89 Pro Gear
35 spline axles
Spool
Wilwood Dynalite Pro series Rear Disc Brake kit 140-2118b
Russell 672330 Brake line kit
Strange Engineering Master cylinder 873-b3360 1.032 bore
Summit racing Brake proportioning valve, adjustable
Summit DS loop
Prostars
26x8.5 15 Sportsman Front runners
15x6 3 1/2 Back spacing
33x19.5-15 Sportsman out back
Interior:
Nv Autometer gauges
Electric speedo 105-7488
Fuel sender 105-7313
Voltmeter 1057392
Temp
trans temp
Tach
Oil Pressure
Hurst Pistol Grip quarter stick shifter With Trans brake button
Neutral Saftey switch (functional)
Pioneer 4x6 speakers
Pioneer Door speakers
pioneer Deh p4000uB Head unit
1998 S-10 high Back bucket seats with arm rests
5 point Racing harness for driver and passenger
Custom Rollbar
Exterior:
Steel 2 1/2 inch Cowl Hood
1998 S-10 Front end conversion
Steel Rear Roll pan
Spray in bed liner (I am having this redone as it was lifting in the current pictures)
Relocated battery under truck with kill switch mounted in gas door opening
15 Gallon Fuel cell with 90 ohm sender
The Truck was painted factory burgandy from a 1994 s-10
The bad
The door panels have some fading near the window and I am missing the trim ring around the interior pull handle on the driver side.
Rear tailgate handle trim ring is missing
Unfortunatly the truck has a rebuilt title, The previous owner purchased a cab to replace The orignal and never noticed the title came as "rebuilt" From the salvage yard.
This Truck has never been in a collision and Everything is new or almost new. I am sure that I have missed several parts or details on this truck and have all reciepts to back it up.
I am selling it to fund other projects but am also open to trades.
15k for the Truck
Flyingorangess@hotmail.com
563-505-Four Three 99
Possible trades would be:
Typhoon
Syclone
Lowriders (63 impala)
Bagged stuff
Hugger orange ss camaro
ls based engine parts
Crazy car audio stuff
Cts-v
Well, I guess pretty much anything....
