1993 typhoon
tyfoo
I checked the wheels the front are labeled and the back are to
there correct.
I don't understand how it can be
if theres a pin in the spring and block.
any ideas?
wrx2typhoon
I would like to get to the bottom of this as well,I just lowered mine and noticed the rear drivers sticks out farther than the passenger.I put it on a lift and double checked everything. Its all where it should be.Yet i have the same problem about 1/2" more tire on the drivers side.
Somebody who knows how to fix this please speak up.
Adam
CAMSTY
SyTy Obsessed
I think most of our truck are like that, Tony and Nolan brought it to my attention last summer and after that i noticed most of the ones around here are off a little.
tyfoo
if its not supose to be that way
then you could cut the blocks off of the axel and move them.
but it may change the alighntment of the drive shaft
maybe good maybe bad.
I know when i got my ty a new drive shaft was installed (maybe connected?)
maybe gm messed up?
if there was 2 different angles on that universal joint it would cause damage
I don't think my truck has been lowered?
maybe someone can shed some light on this by the photos
I do know that the shocks are blue and yellow and the pump is't hooked up
I could put it on a frame rack that may tell whats up if anything
odium
1BADGMC
My driver side rear is out about half an inch when compared to the passenger side. I have dropped Beltec leafs and the installation was done before I got the truck. I figured it was normal since it isn't noticeable unless you know what you're looking for.
