Black on black. 49k miles. I've owned the truck for about a 2 1/2 years and did some minor mods during that time. When I purchased the truck, it had a fuel pump and boost leak issue that i chased for a little while. I upgraded the pump and throttle body and it runs awesome. I also put a new heater core from GM in it, updated the resistor, blower motor, and switch relay. The truck is super clean. Original paint, cladding, wheels, exhaust, etc. Inspected in a PA until June 2013. I've enjoyed it and am ready to move on to another syclone or buick. Somebody will really be getting a nice original truck that is reliable and catchy, I get questions about it constantly!
-Stock Exhaust
-Stock untouched bottom end
-Stock stock untouched heads
-Walbro 255
-QA-1 12 way adj. rear shocks
-RPM 52mm throttle body
-RPM vaccum brake hose with AN fitting w/ boost tap
-RPM cold air intake
-RPM charge pipe
-RPM fuel pressure gauge
-halfast enginuity EGR delete
-Innovate wideband (all electrical ran, needs o2 bung welded into test pipe or aftermarket exhaust, your choice)
-VDO 30psi gauge
-Hot wired intercooler pump
-New cap and rotor
-Taylor 8MM wires new plugs
All the "Josh Straub" tricks
$14,500
I can be reached at 7248430771
image hosting without registration
how to screenshot on windows[img=http://s12.postimg.org/fg4duqw31/tyside.jpg]
image hosting site over 5mb[img=http://s9.postimg.org/t7f26v2wv/typassenger.jpg]
image upload no ads[img=http://s12.postimg.org/fu5pucg6l/tyinterior1.jpg]
screen capture program[img=http://s22.postimg.org/4km6fdev5/tyseats.jpg]
screen shot on windows[img=http://s12.postimg.org/5y4mupael/tyinterior.jpg]
screenshot tool
-Stock Exhaust
-Walbro 255
-RPM charge pipe
-VDO 30psi gauge
-New cap and rotor
$14,500
screenshot tool
